Author Topic: 1927ew difficult gear change  (Read 2539 times)
Offline bailey3
« on: 19 Aug 2011 at 22:09 »
hi can any one help i have difficulty getting into first gear o my 1927 ew
Offline kmd
Re: 1927ew difficult gear change
« Reply #1 on: 20 Aug 2011 at 07:59 »
First thing i would check is the inkage select 1st gear then remove the pin on the gearbox and see
if the leaver moves if not replace that pin, Then do the same on the upper linkage.
If this does not work you will have investigate inside the gearbox.
Kevin
