Author Topic: TS Wheel  (Read 4168 times)
Offline ste
TS Wheel
« on: 01 Mar 2011 at 09:15 »
I'm looking for a front wheel for my 1924 TS project. Surely, someone out there has a 26" wheel they would part with.
Re: TS Wheel
« Reply #1 on: 01 Mar 2011 at 15:00 »
Hi Ste
   Invariably wheels as bought are only good as a pattern. The rims will be rusty and pitted, the hub will require complete renovation even if it is salvageable. So your best bet is to buy a new rim from the VMCC, a replica hub from the LDMCC pre-war spares section and a set of spokes from one of the numerous wheel specialists. If you are not able to build the wheel yourself the wheel specialists will do it for you. All the better if you can find an original hub but that will generally require at least skimming polishing and re-nickel plating and new balls assuming the cups and cones are OK. The Club replica hubs with modern sealed bearings come complete with spindle and nuts. Pilot holes are provided which require enlarging to suit the spoke gauge chosen and countersinking. Polishing and nickel plating are also required to make a concours job. You can get the spoke lengths from the rear wheel as they are the same. Spares from The LDMCC are only available to members. The VMCC will supply rims to anyone except to North America. Chris.
Re: TS Wheel
« Reply #2 on: 01 Mar 2011 at 22:34 »
There is a mob making rims in NZ - Christchurch I think, someone on the forum will know the name I'm sure. I've seen their rims and they are very high quality indeed.
Offline oily bloke
Re: TS Wheel
« Reply #3 on: 02 Mar 2011 at 06:49 »
This might be the outfit you are looking for;
http://www.vintagerims.com/Beaded_Edge_Vintage_Rims.html
Good luck.
Offline ste
Re: TS Wheel
« Reply #4 on: 03 Mar 2011 at 03:42 »
Thanks for the advice Chris. I know where I can get a new rim made, at not a bad cost.  It would be nice to see the frame on a pair of wheels at some stage.
Thanks again.
Stephen
[quote from previous message removed. 03mar11. -Doug, Site Moderator]
« Last Edit: 04 Mar 2011 at 00:35 by Doug »
Offline ste
Re: TS Wheel
« Reply #5 on: 03 Mar 2011 at 03:44 »
Many thamks for that.
I've rung them and got a quote.
Stephen
Offline ste
Re: TS Wheel
« Reply #6 on: 03 Mar 2011 at 03:45 »
Many thanks, I've got in touch with them.
Stephen
