Author Topic: Air release valve spring  (Read 2135 times)
Offline carcrank
    • Carcrank A day in the life of an old car tragic
« on: 20 Feb 2011 at 05:56 »
I'm just about to put the TS engine back together and I'm looking at the spring for the air release valve that goes in the end of the crankshaft. The one I have seems too strong as all it has to do is hold a ball against a seat but then again it did seem to work as the cams and lifters are in good shape. Does anyone have dimensions for one?
Re: Air release valve spring
« Reply #1 on: 20 Feb 2011 at 06:07 »
Hi Carcrank
   The correct tapered spring for this application together with a new 1/4" ball is available from the LDMCC Pre-war spares scheme  for members of the LDMCC.
  Chris.
Offline carcrank
« Reply #2 on: 20 Feb 2011 at 07:36 »
Thanks Chris,
I missed them, they were under "Springs" mmmm should have looked there.
Mark
