Author Topic: EW600 Crankshaft  (Read 5230 times)
EW600 Crankshaft
« on: 15 Oct 2010 at 19:49 »
Hi folks, I am in a bit of trouble with my new E28 - the crankshaft is actually VERY sad - can anyone help me out with a serviceable one ? Top $ paid for the right one !!
Offline podge
Re: EW600 Crankshaft
« Reply #1 on: 16 Oct 2010 at 16:41 »
Hi Ian
I have a lot of spares for the E 29 600 c.c Douglas which may be identical to the E 28, including a crankshaft and a spare engine. The priced list is attached, post and packing extra. Hope this is of interest and can get you on the road. I have two Dougies - 1932 A 32 and a 1951 Mk. 5.
Paul
« Reply #2 on: 17 Oct 2010 at 06:09 »
Hi Paul, note sure how similar they are - anyone comment on whether the 29 stuff would be the same ?
  • Global Moderator
« Reply #3 on: 17 Oct 2010 at 20:12 »
Ian,
The crankshafts are the same. There are only a few detail differences between the 1928 and 1929 engines. The most visible is a change for 1929 is the timing cover and a switch to an corbel mounted Enots sight glass for the oiling system. Less noticeable is the cylinder castings changes slightly around the tappet chest to close off the bottom. With the exception of carburetors updating to the 1929 offerings, I think most everything else on the engine remained the same.
« Reply #4 on: 17 Oct 2010 at 20:25 »
Thanks Doug - Paul I am interested if the crank in the motor is good - will PM you
Offline podge
« Reply #5 on: 18 Oct 2010 at 13:26 »
Hi Ian
Thanks for your mail.
(1) Spare Engine -  this has been rebuilt and the crank is OK. The engine number is EH 806. which puts it at at 1927 or 1928 since it has an outward facing oil sight - as Doug says the 1929 had a rear facing oil sight mounted on a corbel. The EH series were only manufactured between 1927 and 1929.
(2) The worn crankshaft - this is complete with two con-rods, The taper is a bit worn with some minor ridging that would probably clean up, but the opposite end has been rogered a bit by the inept use of a club hammer!
If you want  spares it would probably be cicumspect to have both.
Paul
« Reply #6 on: 18 Oct 2010 at 21:17 »
Sounds good Paul - I will email you to organise how we can proceed !!
« Reply #7 on: 17 Dec 2010 at 08:07 »
Folks - am still on the lookout for a good crank to put the bike on the road.
Offline Daren W Australia
« Reply #8 on: 17 Dec 2010 at 20:28 »
Hi Ian, so who bought the EW600 engine in wollongong for $1200 off Ebay about a month ago. I thought you may have I may have a crank but my vintage stuff is stored at mum's up near Grafton as I just bought a house in the blue mountains. i will probably go pick up some stuff in june Regards Daren
« Reply #9 on: 17 Dec 2010 at 21:39 »
Was that the one from the motorlife museum ? I missed it - but if its that one then its crank was VERY sad
