For Douglas enthusiasts worldwide since 2004
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Home
Help
Search
Login
Register
Douglasmotorcycles.net
General
Douglas Motorcycle Discussion
E28 kickstart spring
« previous
next »
Print
Pages:
1
Author
Topic: E28 kickstart spring (Read 3096 times)
Ian
Master Member
on:
22 Sep 2010 at 00:14 »
A quick question re kick start springs - by E28 has a flat metal spring for the kickstart return - it does not seem to be strong enough as the weight of the kickstarter overcomes it - without the actual kickstart level attached it all works fine. Is this the correct type of spring for these ? If so I guess its probably just worn out. There isn't enough slack in the spring to do another 360 degree turn.
Logged
Administrator
Re: E28 kickstart spring
Reply #1 on:
22 Sep 2010 at 00:45 »
Ian,
Do you have the spring anchored on the correct stud? It is the one immediately above the kick start shaft; not the through bolt below and to the rear. That would give it another 90 degrees tension.
[fix typo, 21sep10]
Last Edit: 22 Sep 2010 at 02:22 by Doug
Logged
Ian
Master Member
Reply #2 on:
22 Sep 2010 at 01:19 »
Hmm - thats interesting - its actually on a separate bolt in front of the shaft - I will try one of the others !
Logged
Print
Pages:
1
« previous
next »
General
