Hej
For more than 20 year, I have used a product for tank sealing,- with the name "SCOTCH-CLAD 776" on about 25 petroltank without one single leak afterwards.
The product is made from 3M. and is exelent.
It is importent to do the cleaning indside the tank very carfully before sealing.
The cleaning can be done from old nuts and broken glas.
The glasbits can be made from a hardened car window,- broken to bits,- with a hammer on a floor
Pour about 2-3 liter of nuts and glasbits in the tank and close all openings.
Shake tank by hands,- for sometimes long time,- (make your arms very long) - until indside is free from
rust and shells.
Wash with petrol and seal after description
I recomend sealing in two step,-
1 step with sealing diluted to about SAE 10-20 - then empty tank and let dry
2 step undiluted,- empty tank and let dry with a little ventilation indside tank from compressorair or blower.
Leave tank in normal position for about 24 hour with ventilation indside
If you have access to a lathe,- is it possible to do the inside cleaning (on very dead slow) on this machine.
Foto show how to do
Good luck and regards from Edin DK
