2 3/4hp cams
Started by MRD, 20 Jun 2010 at 22:01
MRD
Hi All
I have come across a cam for a 2 3/4hp with a 5 stamped on it. My TS model has a cam with 5B which I'm lead to believe is the standard where as 5A is supposed to be slightly "Hotter" but not so common. But I've never seen one with just 5, can anyone shed any light on this?
Regards      Martin
MRD
Thanks for that, I was sure there was something on the forum but I couldn't find it. I probably put a word in the search box it didn't like.
Regards     Martin
