My gearbox no.2355 (1947 ?) makes a horrible harsh grinding kind of whine ,only when i change down.and run in a lower gear, very embarrasing as you pass people. consulting' spannerama', and the like, i have worked on the final drive as the most likely cause, three times. new sealed bearing, re shimming several times but no joy ! but now i 've noticed that as i withdraw the clutch it stops, untill engaged again. That tells me ,that as the m/c is free wheeling , the final drive (always rotating) is not the cause ?. would i be right then to suspect internal bearings ,or worse ? Today i checked the shock absorber on the final drive as per Eddies most recent advice, seems ok though. OK, if its the worst news ,give it to me, i'm quite battle hardened to this B----- bike by now. Denis .S.
