Finally I gave up,..second major change to my EW and thrid attempt to post this!
Started by Boxer, 03 Jun 2010 at 18:08
Boxer
:B :B :B :B
yes finally I replaced my frontwheel *) caused by nonfunctional brake and wobbling drum. See pictures (if this will work... grace to Dave)
  :B :B :B :B
This is the second major change to my EW, first I replaced the Carb by an Amal 4/002 with twist grip.
  :B :B :B :B
(but I stored the original parts safely away, and in 30 min I can install the original wheel for show)  :wink:
But now it's fun to drive around and really save too.... even in modern city traffic and superb on small roads at hillside.... :mrgreen: :mrgreen: :mrgreen:
Happy driving
Rudolf
*) Honda MT80 wheel with 21" and 2.50-21 tyre
Before...
After...
Rudolf,
No wonder it works well, look at the size of that brake lever compared to the size of the brake drum!  :shock:
