TS Douglas 1923 needs motor repair
Started by glenn, 17 May 2010 at 00:51
glenn
Hi ,
Just wondering if anybody knows a good mechanic that repairs vintage motors in Victoria Australia. I have a 1923 Douggie that needs reassembling however the 2 halves of the crankcase will not come together completely (1 cm gap). Also need help assembling the 2 speed gearbox and clutch.
Thanks,
Glenn
pryfield
Glenn
I have a 1923 Duggie and can possibly help with your problem.  Where in Vic are you ?  I am at Horsham
Nev
