Author Topic: Mark 5 kickstart lever  (Read 2718 times)
Offline nacelleration
« on: 16 May 2010 at 17:38 »
In an attempt to complete the reassembly of this machine we are in need of a kickstart lever & lever for cam for rear brake ( part no. 33671 ). The speedo is in many pieces, so a sound example would also be appreciated, as would a battery carrier & all cables etc. Thanks in anticipation !!!
Offline Dawn
Re: Mark 5 kickstart lever
« Reply #1 on: 17 May 2010 at 15:06 »
Member "Coles 1933" was selling some battery carriers in the for sale section of this forum.  I don't know if they were for your machine/or will fit but that could be a starting point for you.
Also the club may sell some of the cables.  I know I bought a speedo cable from the club many years ago - at a very reasonable price too!
Good luck in your search.
Dawn.
Offline MRD
« Reply #2 on: 17 May 2010 at 15:53 »
Hi all
Its probably worth trying the club for the battery carrier, they used to hold them.
I think you would get nearly all the cables from there as well except the throttle cable.
Its worth trying the club first, that's if you are a member of the Douglas club
Regards      Martin
« Reply #3 on: 17 May 2010 at 18:56 »
I have now sourced the cables !  Thanks again for your interest.
[Prior quote removed. -Doug, Site Moderator]
« Last Edit: 17 May 2010 at 21:08 by Doug »
