Author Topic: EW 350 spark plugs  (Read 4155 times)
Offline oily bloke
EW 350 spark plugs
« on: 10 May 2010 at 15:30 »
Hi all,
The EW rebuild is progressing nicely and the engine is going together with its re-sleved barrels, new valves and guides, Honda pistons and rebuilt crank etc. It occurred to me that apart from 18mm I have no idea what plugs to use! Can anyone hazard a guess what modern plug I should get? I know NGK do a range of 18mm A series plugs but beyond that I'm lost.
Andrew.
Offline roy
Re: EW 350 spark plugs
« Reply #1 on: 11 May 2010 at 12:50 »
Andrew, I use Champion D16 in my EW, had no problems at all.
Regards, Roy.
Offline oily bloke
« Reply #2 on: 11 May 2010 at 15:10 »
Thanks roy. I'll give them a go.
Andrew
