Author Topic: Rear Carrier 1924  (Read 3643 times)
Offline ste
Rear Carrier 1924
« on: 04 Apr 2010 at 12:58 »
I'm about to ask a local engineer to build me a rear carrier for my 1924 ts project, as I don't have one.
Does anyone have any drawings or specs to save me the trouble? I'm lazy!!
OR,  does anyone have one spare I can buy?
Offline MRD
Re: Rear Carrier 1924
« Reply #1 on: 04 Apr 2010 at 14:14 »
Hi ste
Please find a drawing of the 2 3/4hp carrier for 1924 models.
Hope it helps
Regards      Martin
Larger version
« Last Edit: 06 Apr 2010 at 22:31 by Dave »
Offline ste
« Reply #2 on: 05 Apr 2010 at 09:40 »
That is so brilliant!!! Many many thanks.
I'm off to the engineer tomorrow.
Offline Marcus
« Reply #3 on: 11 Feb 2022 at 06:58 »
Thank you Martin for posting that drawing of the carrier.
Does anyone have a drawing of the 1924 TS rear fork that runs from the top of the seat post to the lug that carries the rear wheel please, as I am missing  this and need to make one. I believe that the tube is D shaped rather than round, is that correct.
Marcus
Offline carl denton
« Reply #4 on: 28 Feb 2022 at 12:45 »
it is D shape indeed if you find someone that can make that tube over there would be very interested ?
« Reply #5 on: 28 Feb 2022 at 13:42 »
It was a bit of a tedious job, but when I needed some 'D' section tube, I used a sheet metal jenny with one flat roller and one half round roller, and gradually rolled round tube down to 'D' section. A bit of trial and error was needed to work out which size of tube would produce the required section. The big problem is keeping the tube straight while rolling it.
