Author Topic: EW KICKSTART/ front brake  (Read 3342 times)
0 Members and 2 Guests are viewing this topic.
Offline JERSEYDOUGLAS
« on: 28 Mar 2010 at 16:18 »
Hi my name is andy I habe a 1926 Ew. I have two problems with it. The first is the kickstart. It has no splines left on the kickstart. Does anyone have a spare for sale or know of anyone of makes them. Secondly the front brake is near  to pointless. Does anyone have any experience in getting them to grip better
regards
Andy
Offline jaiboni
  • Douglas is an Dream machine that comes true
Re: EW KICKSTART/ front brake
« Reply #1 on: 28 Mar 2010 at 16:57 »
  Welcome Andy
 The great masters will guide you soon
Douglas is an family to all of us
regards
OM NAMO NARAYNA
JAI MATA DI
OM SAI BABA
« Reply #2 on: 28 Mar 2010 at 20:52 »
Andy,
The servo band brakes can be the bane of the Douglas owner. Some examples through minimal maintenance work great, others with tinkering remain poor performers and dragging your feet on the road would have more effect. They can work very well indeed, but get a few small things wrong and it can seem hopeless.
I would suggest starting out by checking these prior posts on the forum, as they might focus your general question to more specific avenues to investigate.
Article on the servo band brake.
https://www.douglasmotorcycles.net/index.php?topic=338.msg969#msg969
Relining 350EW brakes.
https://www.douglasmotorcycles.net/index.php?topic=2287.msg8267#msg8267
General comments.
https://www.douglasmotorcycles.net/index.php?topic=889.msg2907#msg2907
https://www.douglasmotorcycles.net/index.php?topic=1927.msg7072#msg7072
Trails and tribulations of another 350EW owner.
https://www.douglasmotorcycles.net/index.php?topic=2197.msg7963#msg7963
Brake arm and shaft.
https://www.douglasmotorcycles.net/index.php?topic=2440.msg8823#msg8823
https://www.douglasmotorcycles.net/index.php?topic=3431.msg12530#msg12530
As for the kick start conical spline shaft, you have to be careful as Douglas made many variations of these. Different length and diameter of shaft; and the gear teeth changes from standard to stub, and then to coarser pitches. As others have pointed out here on the Forum, a common mistake by owners is to re-fit the kick start lever to a more upright position so as to have a more generous swing. This is a mistake as the travel now allows the quadrant gear to slam into the internal stop (which is one of the cover studs. This bends the stud, breaks the casting around the stud hole, or loosens/strips the conical spline. Or all of the above. The proper return position for the lever is just slightly above horizontal, as shown in period EW catalogs and literature.
I have not heard of these quadrants being re-manufactured. You could look for a better example, as 350EWs are not that rare (noting comments above.) The alternative is to have a new shaft made and applied to your quadrant gear (if the gear is still in good condition.) Other than the milling of the conical spline teeth, this is a straight forward lathe project.
