Author Topic: Dragonfly Oil Filter  (Read 4361 times)
Offline Red
« on: 24 Feb 2010 at 14:48 »
Hi
I purchased a new oil filter for my Dragonfly from Club Spares. The parts book shows two different part numbers for the felt washers at each end of the filter element. Can anyone tell me how you identify which is which. Certainly one of the washers supplied by club spares is slightly thicker than the other. Does it in fact matter which way round they are fitted? Any guidance will be appreciated
Roy
Basingstoke
Re: Dragonfly Oil Filter
« Reply #1 on: 24 Feb 2010 at 16:33 »
Hello Roy,
                 It doesn't matter which washer goes on which end - they both just make a seal between the element and the end plate.
Offline Red
« Reply #2 on: 24 Feb 2010 at 16:47 »
Hi Eddie
Thanks for that. I couldn't see that it would make any difference which way they were fitted but thought it wise to check first.
Roy
