Author Topic: EW350 Gear change lever  (Read 5087 times)
Offline oily bloke
« on: 11 Jan 2010 at 07:19 »
Hi all
Another question about the 1927 EW350. I am missing the gear change arm. The part that passes through the tank to the gate in the top. Can anyone give me the dimensions of same so I can make a new one?
Andrew
Offline bikemike
Re: EW350 Gear change lever
« Reply #1 on: 12 Jan 2010 at 01:56 »
Hi all
Andrew
Andrew,  Looks to be 10 3/8" is the dimension you need.  Good Luck, Mike B
Offline oily bloke
« Reply #2 on: 12 Jan 2010 at 12:15 »
Thanks Mike,
I was, however, looking for a bit more detail. The length from pivot on frame to clevis on operating rod. The dimension of the lever material through the gate change for example. The measurement you gave is a welcome start. Anyone got any more for me?
Thanks again,
Andrew
« Reply #3 on: 13 Jan 2010 at 01:01 »
Andrew,
Here is a drawing of the gear selector lever, part number 7766. Used on EW350 and EW600.
A link to a clearer A4 size PDF file can be found here.
« Last Edit: 13 Jan 2010 at 02:58 by Doug »
Offline oily bloke
« Reply #4 on: 13 Jan 2010 at 06:18 »
Hi Doug
Your a star. Thanks
Andrew
