4HP pistons
Started by kmd, 27 Nov 2009 at 14:51
kmd
Hi All
Could any one help me with the standard piston (Cast iron) dimensions on a 4HP?
  +Distance from the crown to the centre of the gudgeon pin and overale length.
Kevin
Kevin,
Just checked a used pair out of a spare engine and get one inch even from the center of the gudgeon pin to the top of the piston (flat, no crown.) Overall length from the bottom to the top is 2.75 inches.
kmd
