Author Topic: BELT RIMS  (Read 10270 times)
Offline vintagetinaustralia
BELT RIMS
« on: 26 Aug 2009 at 00:26 »
After many months i have finally got the belt rims sorted.
Metal spinning them was fun but not a good saleable product and sizes were restricted.
They are available in any diameter ( down to 12")and are rolled from 1.2mm sheet and seam welded as per wheel rims. Original rims were 1.0mm and tend to split so we upped the material to 1.2mm.
So far i have very little info on Douglas sizes but the dies are interchangable.
Basically they are a 28 degree vee section, 29mm deep and 24mm wide at the top. Curently availabe for BSA and rudge. So i need some info (cross section dimensions) so i can do the Douglas ones. main dimension will be from the center of the vee to the spoke mounting face.
Pricing is still being thrashed out but estimated to be around $180 to $220 for a 20" blank belt rim.
regards
dave
Re: BELT RIMS
« Reply #1 on: 12 Oct 2009 at 04:08 »
Douglas belt rim samples have arived thanks to Graeme in NSW.
3 1/2 HP 1914 to 1924
and 1915 to 1926 2 3/4 wide
Please corect me if i am wrong with the above info
attached info on basic profiles
Belt rimshttp://i183.photobucket.com/albums/x47/salisburypipes/beltrimprofiles.jpg
Guards C section http://i183.photobucket.com/albums/x47/salisburypipes/Csectionguards.jpg
guards D section http://i183.photobucket.com/albums/x47/salisburypipes/Dsectguards.jpg
Veteran guards http://i183.photobucket.com/albums/x47/salisburypipes/vetguard.jpg
info@vintagetin.com.au
