Hello Clive,
O.K. I will describe below some of the tricks and materials I used to rebuild my EW engine and there is still quite a lot to do to get it finished, luckily it is winter here, so I can carry on the work without distraction.
I have been using tough steel rings which I shrank on the camgears (after they were machined down) -- hot with 0.05 mm interference fit and then machined new gearteeth on the rings. I understand Douglas used raw steel without heat treatment (case hardening) for cam gears. With this hot shrink fit and smooth and precise surfaces no tack welding is required. The steel I used is a type which kind of work hardens.
I have also repaired the original EW tappet guides by using phos. bronze valve guide liners. Please see the attached photo. The guides are bored out in a lathe chuck with a special drill/reamer, a sleeve is air driven in with a special tool and then a tungsten carbide ball is driven through the liner to calibrate it and to fix it in the tappet guides. This type of repair has been around for a while and is used extensively for quality repairs of valve guides in automotive engines. I have even used these guide liners to repair some of my girder forks – very efficient, quick and long lasting.
I had to calibrate the diametre of the worn tappets first of course. I did it with a diamond file and using a special abrasive stone lapping gadget I bought from the USA. It can also be used to lap down to size valve stems in a lathe. It took me a couple of hours to achieve a satisfactory finish and equal diametre throughout the length of the tappets.
By the way I received fitting recommendations from TKRJ regarding running clearances for their 62 mm HONDA piston I am using for my EW. They say 0.055 -- 0.065 mm. That is for a modern air cooled cylinder. I fitted mine with 0.08 mm front and 0.12 mm rear cylinder clearance. I have Flex-Honed the cylinders so they will not require any extensive break in period.
This is it for the moment.
LATDOUGNUT
