Eddie,
Thank you for your help in the matter. Unfortunately by the time I read it I had already modified the spare selector cam I had!
I re drew the curve for second gear, in so doing had to increase the ridge by an 1/8 of an inch. This I did by careful welding first on one side then the other to minimise distortion. When it came to cutting away the opposite side to allow the selector pin to slide through I used a Dremmel with a miniature grinding disk, it was the only way to cut away the hardened steel. The welded side was easier and finished touching it, after a file with emery cloth. I was considering hardening it with Kasenite, but as the selctor pins have rollers, thought it should be ok.
Went for a ride this after noon. All 43 miles of them, for the first time on the Mk 4 and having a blast. I m so so glad it worked. I have no hesitation suggesting such a remedy, it was simple just time consuming. I had to check that there was no end play in the layshaft, for if there was it would have buggered up my calculations. So now, second gear dog teeth mesh the layshaft by the full depth of the teeth and so does third.
On a nother tack, I m coming to the conclusion that setting two carbs is not as easy as I thought it was in my Mini days! Would a balance pipe between the two make a difference? I don t have 2 spare carbs to drill holes into.
Cheers once again, Alex
