....i have taken it apart cleaned, counterbored the rivets that were sitting flush with the clutch material and tightened up the spring tension, but no help...tore down again for another inspection and found no reason other than clutch material may be saturated with lube and possibly the material is thin or springs weak.
i installed stiffer springs but it still slips...my observation is the diameter of the springs and the diameter of the clutch material are quit far apart and with the thin metal of the plates(along with some corrosion) they may flex some causing a weak link in the clutch?....can anyone possibly give any thickness dims or shed some light? i would think with the adjustable springs the material thickness should not be a big concern. i do have play in the release plate mechanism so i know the clutch is not disengaged with the clutch released(out).. thanks joe
