racing douglas
Started by bellytimber, 12 Jul 2009 at 13:13
bellytimber
Hi I am new to the Forum does anybody no anything about this bike <the picture will be posted soon . my Father bought this from pride and clark in 1938 it was a 600 inline opposed supposedly of  racing heritage we were wondering if the bike is still around reg number JJ7632
It would be nice to locate it or understand some of its history
thanks in advance
paul
Paul,
If a 600cc, it would be a G/31, G/32, or G/33 depending on the year it was made (1931-33.) If a 500cc, it would have been a F/31, etc. It was Douglas' sporty road model offering of the time. It was not sold as a racing machine, but the engine was based on and used components and modified patterns of the recently obsolete Dirt Track models.
The only oddity is the front forks. Per catalog illustrations, the F/G models used a front fork very similar to the Dirt Track models, with concessions for brakes, mudguard, and attaching a headlamp that the Dirt Track machine did not require. That is not the fork fitted to this machine, which is more like the forks fitted to other Douglas road models of the1934-35 era. It may be this is a 1933 model and that is what they fitted that year when the old stock of Dirt Track forks ran out (perhaps even running out in 1932.) It also has the large barrel compression spring centrally located, which featured from 1933-34 onward. Also supporting this theory is I do not know of any other brazed lug construction fork with the brake drum on the right that would also have the four point head lamp mounting. The side valve models and the OHV models of 1934-35 had the brake drum on the left. OHV models up to 1929 had the brake drum on the right, as did the F/G31. But they did not have the four point headlamp mounting; that came after the twenties. In other words, these forks seem unique.
I have not yet seen a period published photo for a 1933 F/G model, and indeed the factory was in severe financial distress that year and output was almost non-existent. Only magazine adverts indicate they did, or intended to, produce the F/G in 1933. The F/G model was significantly redesigned for 1934-35 and became the OW/OW1 models.
eddie
The forks look to be the same type as fitted to the S6 (allbeit with the brake anchor on the other side). The bottom links have the large dia end for the side dampers as fitted to the S6 and also the rear extensions which form the steering stops. The fitting of this type of fork should have been straight forward as the F and G frames had the larger top steering head bearings similar to the S6. Another interesting feature is the S6 toolbox fitted upside down to the nearside - the lid appears to have been modified so that it still opens from the top. This begs the question - "could this have been another machine built up by Pride and Clarke from available spares?" - as they did with the Dragonflies when they ran out of genuine parts.
