Author Topic: RE Carb,valve and Mag info for Endeavour model  (Read 3357 times)
Offline Endeavor
« on: 25 May 2009 at 01:30 »
Hello
Heres my wish list
I would like to comfirm the following
1) needle jet size as mine has had its number filed off
2) valve timing in degrees
3) mag information that is stamped on the mag ID plate
4) ignition timing fully advanced position
5) A dimensioned sketch of the original air cleaner for this model if you are lucky enough to have one. A Amal book lists  a very similar one as 30/310
6) Spark plug type
Alastair
« Last Edit: 12 Jun 2010 at 10:24 by Dave »
