Head geskets for DT's
Started by kmd, 07 Apr 2009 at 12:01
kmd
Hi All
Can any one help me with information about head gaskets the copper O ring for DT or overhead valve models?
Is there an alternative or a suppler of these large O rings as per war spares do not hold this item yet?.
Kevin
Ian
I would certainly be interested if you find a supply - we just used flat copper.
Kevin,
There is a discussion on manufacturing DT head joint rings in this post.
https://www.douglasmotorcycles.net/index.php/topic,261.msg697.html#msg697
