Author Topic: Carby for 1924 TS  (Read 6516 times)
Offline ste
Carby for 1924 TS
« on: 08 Mar 2009 at 05:19 »
Can someone tell me what model carby will go with the 1924 TS please?
Amal or Amac and what model?
Is it also possible that export models had different carbs to British models?
Stephen
Re: Carby for 1924 TS
« Reply #1 on: 08 Mar 2009 at 05:38 »
As far as I am aware it is usually an AMAC - depends on which inlet manifold you have as to which one - updraft or sidedraft
Offline ste
« Reply #2 on: 12 Mar 2009 at 08:47 »
Thanks. I don't even have a manifold yet, but I know where I can possibly borrow one.
Progress on the frame. It has been blasted and has exposed multiple holes. It's now in an engineering shop having the holes repaired.
I assume the back bars that support the footrests, should be flat, and not bent up like mine?
« Last Edit: 12 Mar 2009 at 19:39 by Dave »
« Reply #3 on: 12 Mar 2009 at 10:15 »
Yes - thats correct - they should be flat
Offline ste
« Reply #4 on: 13 Mar 2009 at 07:18 »
Thanks for that. Should the front ones be longer? Have extensions?
Stephen
« Reply #5 on: 13 Mar 2009 at 09:03 »
Hi Stephen
    It depends upon which model you wish to restore it to. If you want footboards then extension tubes may be fitted. If you require footrests on the rear cross tube then domed tube end finishers held in Pre-war club spares by The London Douglas MCC are simply pushed into the ends of the small extensions from the bottom front frame lug. Chris.
Offline ste
« Reply #6 on: 13 Mar 2009 at 20:59 »
Thanks Chis. I used to be a member back in the 1990's. Sounds like I should join again.
Stephen
