distributor points
Started by tony, 31 Jan 2009 at 18:37
tony
hi i need a new set of dist points /condenser/rotor, for my 1957 dragonfly any advice would be gratfully recieved regards tony
eddie
Original spares for Miller distributors are now almost impossible to find, but providing the body of the rotor arm is sound, a new contact and spring can be cut from sheet metal. Any condenser from a Lucas distributor can be utilised - they don't seem to be voltage critical ( I have used Vauxhall Viva condensers in the past). The points are more difficult to obtain - they were only used in the Dragonfly and one model of Scott and, I believe, the Trojan van. Similar points which can be modified were used in the Siba Dynastart that was fitted to Villiers engines for use in invalid carriages - in fact they used two sets, one for forward direction and one for reverse!
tony
#2
hi eddie, thanks again for info all noted hunt starts now regards tony
Quote of previous message removed - Dave, 1st Feb 09
