Magneto mounting - 1930 S6
Started by Michael Scott, 22 Sep 2008 at 14:49
Michael Scott
 :question:  Can anyone help me with a dimension drawing of the "plate" that goes bewteen the crankcase and the base of the magneto on my 1930 S6 retoration?
Obviously the thickness is critical and I could reasonably easily measure up the rest of the piece which I presumably will have to manufacture.
regards
eddie
Michael,
              The magneto on an S6 does not have a plate - instead it sits on 4 steel buttons to help insulate it from the heat of the engine. In the top of the crankcase you will find 4 holes about 3/16" dia to take these buttons. I will measure the buttons for my S6 and post the dimensions tomorrow.
Michael,
See also this post for a similar question, with pictures of the tablet spacer (well, a replacment)-
https://www.douglasmotorcycles.net/index.php/topic,2116.0.html
Michael Scott
Quote from: eddie on 22 Sep 2008 at 18:41
Michael,
Many thanks.  I had noted the witness marks.  There are two indents on the bottom of the magneto which led me to wonder if there was a plate with posts on each side
regards
eddie
Michael,
               I have checked the magneto pads on my S6 and they are .750" dia x .200" thick with a spigot .187"dia x .125"long on the underside.
Michael Scott
 :)Many thanks
I will get the trusty lathe fired up
