Author Topic: Points problem  (Read 2965 times)
Offline Alex Hall
Points problem
« on: 19 Jul 2008 at 07:23 »
After much grief I have finally got both the bikes firing regularly and one running wellish. The biggest problem I had was some arcing taking place inside the points between the spring and the centre brass point carrier. Has this happened to any one else? To solve it I used some heavy insulating tape between the two parts, but will look for some plasitc clip which can attch itself to the spring for a more permanent solution.
Also found a cam with distinctly worn lobes, does any one know what the oroginal profile should be like or is the build up a matter of a gentle ramp to open and then close? Cheers and thanks to All
