The S6 spares list, besides an "oil-thrower between spring and flywheel" (?), mentions a "spring location washer" and an additional "washer for bearing" in the drive side. So there are bits in there that could have been omitted during the last rebuild. The timing side is just a plain bronze sleeve on these engines, and does not contribute much to axial location, or is not intended to I think!
Also, I do not know if it is the practice with the S6 types, but certainly on other Douglas engines Kingswood was not very precise about machining crankcases, particularly on the side valve models. It is not uncommon to remove what appear to be original bearing races, and to find neatly made shims behind the outer race. The practice seemed to err on the deep side and shim out extra play behind the outer race, rather than between the inner race and the crankshaft.
Now I probably could check all this as there is an S6 engine in bits out in the shed packed away. But as it is also about -12 Celsius out in the shed at the moment, and I am not that dedicated, sorry! Perhaps someone presently enjoying a warmer climate would oblige?
