Author Topic: Advice on larger bore/pistons  (Read 4420 times)
Offline sidecar willy
« on: 19 Dec 2007 at 19:49 »
Hi...I am sure Doug will be able to help here.
I recently picked up a spare 250 cc Comet engine which looks as if its been well used with the inside of the timing cover and crankcase gummed up with thick black oil [indicating either high mileage or that the oil never got changed]The engine came complete with a magneto and pancake dynamo. Good spares.
I intend to have the engine overhauled with new bearings and pistons...but as I will have a rebore on the cylinders..just wondering how far I can go with larger pistons. There looks like a lot of meat on the bores...and assuming I can get larger pistons thought I could take the bore out as far as I can take it. Of course this puts a strain on the bottom end...but with new bearings this might be possible.
Any ideas from the forum would be handy!!!
cheers
Bill
Offline Edin
Re: Advice on larger bore/pistons
« Reply #1 on: 19 Dec 2007 at 20:27 »
Any ideas from the forum would be handy!!!   cheers  Bill
Hej Bill
3 or 4 years ago I made 250 Comet from the bottom.  As right I remember, I found out at that time, the 250 and 350
cylinders are identical - with exception of cylinderdiameter. I have stil many parts from that project.
kind regards Edin DK
Edit:  Quote tags adjusted 20/12/2007.  A.
« Last Edit: 20 Dec 2007 at 00:28 by alwyn »
