Author Topic: Hi! And help with Aero 250 rebuild -Brake arms  (Read 6730 times)
Offline Rollo Turner
« on: 06 Dec 2007 at 22:46 »
Hi to all Douglas owners out there and I am hoping you can help with my rebuild of a 1936 Aero 250. I am starting with a box of bits in reality and the first thing I want to do is get a rolling chassis up and sorted. This means wheels and the brakes. It turns out I probably do not have the brake actuator arms (front and rear) which I assume double as the brake torque arm as well but I am blowed if I can see how that works. Anybody got one they could send me drawing/photos of so I can understand how the set up is supposed to work and then possibly make some up?  Better yet anybody got a couple of spares....!!
Thanks for any help
Rollo
[added to subject title. -Doug]
« Last Edit: 07 Dec 2007 at 05:42 by Doug »
Re: Hi! And help with Aero 250 rebuild
« Reply #1 on: 07 Dec 2007 at 05:41 »
Rollo,
Yes the brake shaft does also take the reaction from the brake torque.
The brake arm shaft passes through the bushed lug in the front or rear fork, and the splined shaft engages the spline in the brake band bobbin. Working the brake arm rotates the bobbin and so expands the band and applies the brake, but further prevents the bobbin and so the whole band from being dragged around by the brake drum. Here the brake arm an bolt are new.
The backing plate is really no more than a dust cover and convenient place to anchor the brake return springs. It does not transmit any of the braking loads. It is a good thing too, as they are not very strong!
Here you see the opposite side with the brake arm 'plugged in'. This is an original brake arm; you can tell an original as they are usually bent!
As they used basically the same lever on nearly all models from 1925-1938 (they did get a little more robust as time passed, and some rear arms had a slight joggle to clear the frame), you should stand a good chance finding some to suit. Try posting in the parts wanted section. The new one shown above in the first image was made using a manual lathe and mill, plus and a file, so you do not really need anything special beyond having metal working machinery or a local shop or friend with same, and a sketch/drawing of an original brake arms to copy. I do not know if your particular model was one that used an identical arm front and rear. The shafts I think will all be the same.
[update image links to https.  22Aug19  -Doug]
« Last Edit: 22 Aug 2019 at 18:14 by Doug »
« Reply #2 on: 07 Dec 2007 at 08:34 »
Thanks Doug - exactly what I needed. You are a star!
Rollo
Edit: Full quote including images removed. A.
« Last Edit: 07 Dec 2007 at 10:47 by alwyn »
