Author Topic: 1926 CW conrods and cam driver gear  (Read 5397 times)
Offline macka
« on: 24 Nov 2007 at 01:23 »
Hi all,
Can anyone help me with a set of 1926 CW conrods and an original piston to take dimensions from.
Also looking for the small cam driver gear fitted to the end of the crank as the one I have is very badly pitted.
Thanks Macka.
« Last Edit: 24 Nov 2007 at 05:43 by Dave »
Offline Alan
Re: 1926 CW conrods and cam driver gear
« Reply #1 on: 27 Nov 2007 at 23:45 »
Just a comment that the engine gear tooth profiles for Duggies of this period are often the same as that used on British lathes etc for many years..spare gears for lathes are available (alas my supplier has disapeared). Some machining is needed as lathe gears are normally wider and have different bores, but I used these on my B29 and worked well..Hope this helps.
Offline macka
« Reply #2 on: 14 Dec 2007 at 09:21 »
Hi all,
Im still looking for the cam gear and also a kick start lever for the same bike.
Thanks, Macka.
