Author Topic: Pinnion nut  (Read 3440 times)
Offline sidecar willy
Pinnion nut
« on: 03 Sep 2007 at 18:53 »
Hi...I am stripping out the engine of my 250 cc Comet to check out bearings, crank shaft etc. Removed timing cover, removed cams and shafts. But to split the crankcase I need to remove the pinnion at end of crankshaft..the one that drives cams and oil pump drive. There is lock nut/key shaft that holds on the pinnion ...the question is ...is this a left hand or right hand thread?
cheers
Re: Pinnion nut
« Reply #1 on: 04 Sep 2007 at 02:53 »
The nut/drive dog is a right-hand thread.
Re: Pinnion nut
« Reply #2 on: 04 Sep 2007 at 05:22 »
Doug...once again you come to the rescue. Thanks
