Hello Mike , What you have with the cylinders is correct the valves on EWs never match the centre of the mushroom but to the edge of the circle as indicated. The G number indicates matching halves and probably batch number. Your timing cover bolts however are incorrect and seem to enlarged considerably. The considerable amount of corrosion where base of cylinder meets case can probably be hidden by the base gasket. Pay particular attention to bronze screw ins as these are sometimes cross threaded and the inner loop becomes broken or cracked. regards Al
