Author Topic: Dragonfly 1959  (Read 3734 times)
Offline allan
Dragonfly 1959
« on: 09 Aug 2007 at 15:15 »
Can anybody help me find a coil, condenser and points for my bike, it seems very difficult to find parts suppliers...
Re: Dragonfly 1959
« Reply #1 on: 09 Aug 2007 at 17:18 »
Hi Allan,
              Miller  parts are becoming very scarce now - however the coil can be replaced with a 6 volt Lucas unit. Regarding condensors - they do not seem to be voltage sensitive - I have been running my Dragonfly for about 10 years on condensers for a Vauxhall Viva. The points are a problem because they have to be very compact to fit in the Miller distributor. You could try looking for points for a Syba Dynastart (as fitted to Villiers engines used in invalid carriages etc.). The moving point is almost identical (just needs the hole in the end of the spring opened out to a slot). The mounting bracket for the fixed point needs rebending to make it suitable for use in our distributors. Another bonus is that the Dynastart uses two sets of these points - one for forward running and the other for reverse.
           Hope this is of some help,
Offline allan
Re: Dragonfly 1959
« Reply #2 on: 09 Aug 2007 at 21:28 »
Eddie,
Thanks for your help.
Allan
