2024-06-11, 20:02:05
2024-06-08, 18:30:04
For Sale
2024-06-07, 02:13:36
2024-06-03, 08:23:05
For Sale
2024-06-02, 08:34:05
Parts avalable
2024-06-01, 18:33:27
2024-05-28, 00:09:46
Welcome to the new site!
Magneto Leads for 1918-1925 Douglas
Started by gsx1100s, 01 May 2007 at 04:29
gsx1100s
I have in my possesion some heavy gauge electrical wiring.As  I have to replace my magneto leads, I was wondering if this wire would be acceptable. The original wiring is far thinner compared to the wiring I was thinking of using .
cheers michael
Alan Cun
Quote from: gsx1100s on 01 May 2007 at 04:29
cheers michael
What looks best for high tension wires is a plastic lead covered with yellow and black flec braid there are two sizes a thick one (dull colour) mainly used for vintage cars.   There is a thinner one with shining finish that fits the EIC pickups  I prefer to use a brass round plug wire end with a flat section hole for the spark plug.   I came across some plastic  NGK plug cap ends recently we put a meter on them and they had resistance so dont use with magneto.     Cant remember who sells the braided wire I usually get it from a trader from Sydney  or Melbourne who frequents larger swap meets.   Anyway you can try your local auto elec for black wire but make it wire not resistor lead     regards Al
gsx1100s
Thanks Al for your advice , I'll look into the dealers you suggested,
cheers Michael
graeme
Try Vintage Wiring Harnesses in Melbourne - they certainly stock the lead for magnetos.
gsx1100s
Quote from: graeme on 02 May 2007 at 06:11
Thanks Graeme , I live close by to them! a great stroke of luck.Is there a particular length specified for the Douglas as to the leads ? Or is it a matter of choice.
cheers Michael
graeme
They sell it off the roll Michael - so just order a bit more than you will need and cut it to length. I would think that for a 2 3/4 if you ordered a metre it  should be more than sufficient. They should also have the brass tags you need for the plug connection as well.
Cheers, Graeme
gsx1100s
Alan Cun
Dont know how far you have progressed     but it may seem like working backwards     fit the brass end on cable first     The internal wire is usually soft and  when trying to remove the outer cable  oops off goes the wire too and the cable may be short    Al
gsx1100s
Quote from: Alan Cun on 06 May 2007 at 10:55
I have bought two types of brass ends. One is the type that spikes into the wire and is then crimped. the brass attaches onto the spark pliug with a clip.
The other type , the wire is stripped then soldered into a sleeve . The sleeves' end is flat with a hole in it . this hole is fitted over the plug and then the cap is screwed on.I am guessing that the latter brass end is correct. thanks for the tip Al
regards michael
