Author Topic: Lamp for 1934-35 instrument panel  (Read 6357 times)
« on: 27 Mar 2007 at 23:17 »
Need a instrument/inspection lamp for a 1934-35 Douglas instrument panel. Goes in the vacant hole as indicated by the arrow. I believe it is a standard Lucas lamp as used on other panel mounted instrument panels of the era, like Triumph and Ariel. I just need the removable lamp, as I have the base still riveted to the panel (they were unable to steal that), but I have a friend also restoring a '35 Douglas, and he has a lamp but is missing the base. So if a complete lamp and base were to be available, then two Douglas owners would be helped out.
Larger view
Here are pictures from a 1934 Douglas of the desired lamp-
Larger view
Larger view
« Last Edit: 27 Mar 2007 at 23:28 by Doug »
Offline trevorp
Re: Lamp for 1934-35 instrument panel
« Reply #1 on: 28 Mar 2007 at 07:42 »
im no expert on these but i think the part no is dc40 may help narrow your searches
« Reply #2 on: 10 Apr 2007 at 12:42 »
There is a firm in the UK that can supply these lamps fully restored. They cost quite a lot as they are now very rare items. Unfortunately as I am abroad at present, I have no access to my records and from memory cannot recall their name.
If a solution has not been found by the time I return to UK at end of April, I will endeavour to inform you of the source. Chris.
Offline arturro
« Reply #3 on: 10 Nov 2020 at 14:06 »
HI Chris
Old post but I want to return to this topic. Do you have details about this company in UK who supply these lamps on panel tank?
I will be grateful for any answer.
Best regards Artur
Offline tck
    • old racer
Offline arturro
« Reply #5 on: 15 Nov 2020 at 21:00 »
Dear Tim
Thank you for your post but I'm looking for brass type like on photos in this post .
Best regards Artur
Offline Dads bike
« Reply #6 on: 16 Nov 2020 at 00:16 »
Evening Artur
Looking on the net tonight, these people seem to be advertising replicated brass Lucas lamps of the type you are looking for.
imaginemotorcycles.com.ar
cornucopia-enterprises.de have also sold them in the past, currently out of stock but may be worth dropping them a mail.
Steve
Offline arturro
« Reply #7 on: 16 Nov 2020 at 08:30 »
Dear Steve
Thank you for your replay. It help me a lot. I will try to write to both companies. Once again big thanks for you
Best regards Artur
Offline arturro
« Reply #8 on: 16 Nov 2020 at 12:56 »
Hello
I also serch some websites and I foud this auction with Lucas inspection panel lamp
https://www.ebay.co.uk/itm/Lucas-inspection-panel-lamp/283783014092?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
Lamp is brass made in Slovenia
Some additional photos from seller .Looks good .
Best regards Artur
