Author Topic: T35 mk1  (Read 3720 times)
Offline colrose
T35 mk1
« on: 26 Mar 2007 at 19:40 »
evening everybody
i have a t35 mk1 douglas, i need front brake, clutch, rear brake and throttle cables for said machine, also im in need of a rear number plate mount to finish my litttle project off.
would you have any ideas where i could find said parts
thank you
Re: T35 mk1
« Reply #1 on: 27 Mar 2007 at 06:28 »
Hi,  If you are a member of the London Douglas Motorcycle Club, we can supply the brake and clutch cables, but we do not stock throttle cables as the original type junction box is no longer available and the original cables were soldered up after fitting to same. Regarding the rear numberplate: originally this would have been integral with the removable tail section of the rear mudguard. Later Mk series machines had a similar one-piece mudguard but with separate rear numberplate.
              Hope this helps,
