2024-06-08, 19:30:04
For Sale
2024-06-07, 03:13:36
2024-06-03, 09:23:05
For Sale
2024-06-02, 09:34:05
Parts avalable
2024-06-01, 19:33:27
2024-05-28, 01:09:46
Welcome to the new site!
Oil pump question
Started by Ian, 10 Jun 2006 at 08:49
Ian
My OC has a mechanical oil pump which sucks oil through the drip feed. It has a hand pump and a direct outlet from the oil tank which both feed into the input side of the drip feed. This is quite a complex arrangement with two way tap, etc. My question is, will the had oil pump allow oil to be sucked out through it ? If so the I can blank off the other hole in the oil tank and have a very much simplified system. I can' t see why it wouldn't - unless the leather washers put too much force on the side of the body.
