Author Topic: Second fuel tap on tank of 2 3/4  (Read 5041 times)
Offline gsx1100s
« on: 31 May 2006 at 06:01 »
Does anyone know the function of the second tap located on the tank of the 2 3/4 Douglas. I understand the first is a fuel tap , the second though alludes me. It is located closer to the rider in line with the petrol tap.I have checked pictures of the same era and only found a single tap. Is my tank from a later model?
thanks in advance michael
Re: Second fuel tap on tank of 2 3/4
« Reply #1 on: 31 May 2006 at 06:14 »
It is usually used as a fuel drain. I sometimes have a tap and sometimes just a blanking bolt
« Reply #2 on: 31 May 2006 at 07:42 »
All of my 2.3/4 hp models (four) and others I have ridden have two taps in the base of the petrol tank. One is obviously the fuel tap. Ian is correct, the other is the drain tap which terminates with a little cone shaped nipple. An interesting point is that the original Douglas drain taps have the tap operating in the opposite way from the fuel tap, i.e. the drain is shut off when the tap lever is in line with the tap body. The fuel tap is shut off when the lever is at a right angle to the fuel line. On some early models the drain tap is on the other side of the tank from the fuel tap and at the front. Chris
Offline clee
« Reply #3 on: 05 Jul 2006 at 09:52 »
to go with what has been said, it is a drain for the OIL tank. regards col
colin lee
Offline clee
« Reply #4 on: 05 Jul 2006 at 09:56 »
sorry, my mistake, it must be late. looking at 3 tanks, everyone is right, it's just plugged off. sorry about the first post.  regards col
colin lee
