Author Topic: Question about Douglas brochure  (Read 6330 times)
Offline Dave
« on: 23 Dec 2005 at 01:08 »
Steeve emailed this brochure and question today.
Quote from: Steeve
Hi, I’m writing from France. I own a very old Douglas sale brochure, surely from the 20’s, and I wonder what model is … (see the attached file)
Could you help me to find it ? This 2 pages folder is for sale if someone you know is interested ?
Thanks a lot, I wish you a great Christmas time
best regards
Steeve
Larger view
Larger view
« Last Edit: 23 Dec 2005 at 03:20 by Dave »
Re: Question about Douglas brochure
« Reply #1 on: 23 Dec 2005 at 03:06 »
I think it would be a 23 model CW - as it has the Douglas rotary carby which I believe was only available on 23 models
« Reply #2 on: 23 Dec 2005 at 03:56 »
The 1923 had a different style brake, an inverted v-shoe bearing on a very small rotor.  Those half-size dummy belt rim brakes came out with the 1924 models.  Yet the saddle nose spring is the shape seen on the 1923 models, and not the '24s.  So a 1923-1/2?
« Last Edit: 23 Dec 2005 at 04:01 by Doug »
« Reply #3 on: 24 Dec 2005 at 18:06 »
Further to Doug's response I believe the frame types were mixed in respect of the front saddle spring. My 1925CW has the flat clamped spring as opposed to the alternative hooked spring bolted into a block welded onto the top frame tube. The Douglas alloy rotary carburettor was also used through to 1926.
Offline Dave
Offline pryfield
« Reply #5 on: 28 Dec 2005 at 10:27 »
Hi. I would think the bike is 1925 or later. Rotary carb as stated carried well into 1925/26. The flat seat bracket indicates later than 1923. The giveaway to me is the rear sprocket. My original 1924 sales brochure shows a very different design (straight spokes) on the earlier CW models -  Nev.
« Last Edit: 28 Dec 2005 at 11:21 by alwyn »
