I was fortunate to be able to acquire a 1930 Douglas sidecar chassis, which goes nicely with a 1930 Douglas S6 basket case that I have been bringing home piecemeal in my luggage from the UK over the last several years. The sidecar frame and the remaining larger bits of the S6 precipitated crating and shipping the balance, and are now resident in my garage.
Larger ViewThe sidecar chassis has the mounting hardware intact, and it does all fit up to the frame as can be seen. The rear body coil-spring suspension is all there and functional, though it seems to be sprung a bit soft. But unfortunately at some time in the distant past (and two or three owners back), the wheel, hub, and spindle (located at ‘B’, see image below) were removed; probably to make it easier to store the chassis. And sadly it became separated from the chassis and lost. So I need some help. Ideally I would like a sidecar wheel and spindle. Practically that is not likely to happen, so would settle for some drawings/sketches/photos so I can fabricate anew. Also I need information on the mudguard and mounting stays.
Larger ViewThe front body suspension mounts at the bracket indicated by ‘A’. Catalog illustrations show this generally to be a bit of bent flat bar with two coil springs spaced either side. Also it seems the body could be lifted, pivoting about the rear suspension, to service the left side of the engine. It looks like there may have been a long pin that could be pulled out of the front mount, as a quick release latch. Again, more details are sought.
Douglas made pretty much the same sidecar, with small changes to bolt up to the various models and frame configurations, from 1927 to 1936. And I very much suspect that even earlier chassis shared many components, except that they had leaf-spring suspension at the rear. So it would not need to be exactly a 1930 chassis; quite a wide range in years would provide much needed information.
Larger ViewThere was no body, and had there been it probably would only have been fit for a pattern, they generally do not survive very well being of light construction. The image above is from the 1930 sales catalog, windscreen sold separately! To get the hang of an outfit I will fit a simple box body to start with, (perhaps to haul the SW around!) Eventually something along the lines of a Douglas Sports sidecar body is the goal. I saw a fifties era VP sidecar that looked a lot like a Douglas Sports body, though the monocoupe construction was almost certainly far superior to what ever Douglas was using in the thirties. I took some pictures and overall dimensions of that, and will build something along those lines. Genuine Douglas sidecar bodies are rare. However if there are any out there, pictures would be appreciated to use in designing an amalgamation of the Douglas ‘look’ and the VP construction.
