SW5 flywheel clutch
Started by Cliffy73, 22 Jun 2025 at 16:25
Cliffy73
Hi has anyone got a flywheel clutch assembly for an SW5 they are willing to part with.
I would recommend searching for a later 3-pin type clutch from a F/31-G/31 or '32 or the OW/OW1 models of 1934-35. Besides having three drive pins for the pressure plate verses two, you can separate the clutch disk from the backing plate. On the SW5 clutch (2-pin) type you have to un-rivet the sprocket to separate, as the hole in the backing plate is too small to allow it to pass through.
I do have drawings for the later 3-pin type if you decide to go the route of manufacturing a new flywheel clutch. I also have an example of the 2-pin type for my SW5, but it has not been drawn up.
