Douglas comp gearbox
Started by jaiboni, 18 Aug 2008 at 18:14
jaiboni
Respected members
Douglas comp gear box for sale in ebay.com.au
see here
thanks
AUCTION RESULT
Highest Bid: AU $630.00
Auction Ends: 19-Aug-08 13:22:38 AEST
Item Location: Lara, Victoria, Australia
History: 11 bids
Seller: standard10
Seller's Description:
This is a chain final drive Douglas gearbox stamped "comp".  The gearbox seems in good condition. Gearlever has a bit broken off the end and the kickstart pivot bolt is worn. Turns over OK and selects gears. Output drive sprocket is worn.
I am not a Douglas expert so if anyone can pin down what the "comp" stamping on top means feel free to contact me.
The gearbox is located in Lara near Geelong. Weighs about 15 kg so can post OK within Australia and overseas. If you want to work out postage allow a few kilos for packaging and use the Australia Post website postage calculator. My postcode is 3212. I dont charge for packaging or handling.
The copyright for this text and photo is owned by the Seller. It is reproduced here as publicity for the sale only and should not be used elsewhere without the permission of the Seller. Should the Seller wish to have the text or photo removed from display, please email: ebayphotos-at-douglasmotorcycles.net. (replace -at- with @) and it will be removed immediately.
OM NAMO NARAYNA
JAI MATA DI
OM SAI BABA
