Amps
Started by Graham prichard, 21 Jul 2015 at 18:38
Graham prichard
Hi all, I'm going for test ride at night test the new charging ,
When I put lights on, amps go into discharge on amp meter
Does this mean lights will drain battery.
eddie
Hi, Graham,
                     In a word 'Yes'.
   If your dynamo has been out of use for some considerable time, it may have lost it's residual magnetism - so wont generate any charge. To restore the magnetism, remove the 2 wires from the dynamo. Then with another length of wire, connect the 'F' terminal on the dynamo to the live side of the battery for a few seconds - be careful, the wire may get hot, as there will be quite a discharge. Having done this, reconnect the 2 dynamo wires, and start the engine. Providing the dynamo is OK, it should now show a healthy charge.
Graham prichard
I will do this as soon as I get a bit of time ,just had armature done, and yes it had sat around a long time, Eddie I have same problem on 500 royal enfield can I do the same thing this sat about for years many thanks
eddie
Hello Graham,
                     Yes, that should work with any Lucas or Miller dynamo.
