2024-06-08, 19:30:04
For Sale
2024-06-07, 03:13:36
2024-06-03, 09:23:05
For Sale
2024-06-02, 09:34:05
Parts avalable
2024-06-01, 19:33:27
2024-05-28, 01:09:46
Welcome to the new site!
1911 Model D
Started by MichielH, 24 May 2007 at 14:00
MichielH
340 cc (60 x 60 mm) a.i.v.-engine
main changes from type C:
new, rounder shape for petrol/oil tank,
new frame with slightly lower engine position and differtent lug for rear end (positioned a bit higher up)
valanced mudguards
timing gear is now encased.
availlable as single speeder (direct drive) or with two speed gearbox (with primary chain and secondary belt, on the same side!). 'box was also available as a an extra to be fitted later.
pictures from 1911 catalogue and my own model D (single gear)
Michiel
Larger view
Larger view
Larger view
Larger view
More photos added 26th May 2007.
