Hello Eddie,
Thought it best to address this to you as nobody in the club seems to love me. On a test ride recently there was a slight misfire at low revs. On playing about with the pilot screw this afternoon I realised it is the offside cylinder causing the problem, that is where the misfire is, accompanied with a bit of blue smoke. It appears to clear with a bit of throttle, but I am not happy with it. I did check the tappets, they are spot on. I am suspecting the valves need grinding in even though there is plenty of compression. Look forward to hearing yours and anyone Else's suggestions.
Les
