Author Topic: EW 350  (Read 4285 times)
Offline Andreas
EW 350
« on: 12 Mar 2014 at 09:29 »
I forgot to attach the other fotos of the CW or SW and EW 350. Is it EW 350 and which year?
Andreas
« Last Edit: 13 May 2014 at 07:54 by Dave »
Offline David Lawrence
Re: EW 350
« Reply #1 on: 12 Mar 2014 at 11:13 »
Hi Andreas,
Looks like an interesting project!
If you could either publish the frame and engine number it would be a great help for determing  the age, alternatively send me an email directly.
Offline Andreas
Re: EW 350
« Reply #2 on: 12 Mar 2014 at 12:25 »
Hi Dave,
I will have a look to the numbers and let you know. Do you believe the engine in the two fotos above is an EW 350? The timing cover looks different to them what I know.
Andreas
Re: EW 350
« Reply #3 on: 12 Mar 2014 at 15:02 »
Andreas,
The engine in the first two pictures is a 350EW. It was fitted with the optional timing cover of an electric lighting model to mount a BTH pancake dynamo (11-o'clock position to the crankshaft). This and other portions have been machined away, presumably to adapt the engine to a role as a stationary power plant. This seems to be borne out by the non-original flywheel, and extension to the crankshaft on the timing side.
Offline Andreas
Re: EW 350
« Reply #4 on: 24 Mar 2014 at 10:09 »
Hi Dave, hi Doug,
Meanwhile I am owner of the TS, which is a 25. Engine No is 71732, original frame No is disappeared. I have another frame with No 1.064 (?), seems to be the same as the original. Are you able to identify the numbers to the year 1925?
Andreas
Re: EW 350
« Reply #5 on: 24 Mar 2014 at 15:09 »
Andreas,
From the identification tables found here:
Post:
https://www.douglasmotorcycles.net/index.php?topic=488.msg1451#msg1451
Identification table in post:
https://www.douglasmotorcycles.net/aa-files/html/identify-part1/veteran3.3.htm
You can see that engine #71732 date from 1924. The number ranges are not precise, and should be taken as an approximation.
Offline Andreas
TS 25
« Reply #6 on: 25 Mar 2014 at 08:38 »
Thank you for your kind explanation.
Andreas
