Author Topic: Mark 4 battery carrier  (Read 2381 times)
Offline Ian
« on: 21 Oct 2014 at 23:45 »
I am fitting an original centre stand to my wifes MK4 - I notice from discussion on these forums that the return spring is supposed to connect to the battery carrier - I can't see it on mine so assume I do not have a standard one.
Firstly are correct carriers available anywhere at the moment ? I think some people on this forum were making them a few years ago
Also, if anyone has a photo of where the spring should attach I can work something with mine
Re: Mark 4 battery carrier
« Reply #1 on: 23 Oct 2014 at 03:07 »
Ian,
There should be a tab spot welded to the back of the carrier with a small hole for the spring to loop through. The link below to the old auction site articles is of the type used on the Mark 3, but I believe the mark4-5 carriers were very similar.
http://www.kynoch-douglas-parts.com/html/articles/mk%20series%20center%20stand%20spring.htm
