For Douglas enthusiasts worldwide since 2004
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Home
Help
Search
Login
Register
Douglasmotorcycles.net
General
General Douglas Discussion
1921 2.75hp (model W) Rear Reg Plate Mounting
« previous
next »
Print
Pages:
1
Author
Topic: 1921 2.75hp (model W) Rear Reg Plate Mounting (Read 3204 times)
olesuffolkbuoy
Member
on:
23 Jun 2012 at 15:17 »
Looking for some help on correct arrangement for attaching the rear reg plate to the rear mudguard.
Can anyone help with pictures and/or sketches of original brackets or parts that did the job.
Whilst my lower bracket looks the part, I cant believe these two studs would have been the original method!
Thanks in advance,
Tony.
Last Edit: 27 Jun 2012 at 21:42 by Dave
Logged
Chris
Master Member
Re: 1921 2.75hp (model W) Rear Reg Plate Mounting
Reply #1 on:
25 Jun 2012 at 10:03 »
Hi Tony
You are quite correct. The studs are not original. The rear number plate was simply attached by two screws and nuts to the holes in the rear tube of the carrier and then to the mudguard via a "T" bracket leaving the rear number plate at an angle.
Chris.
Logged
olesuffolkbuoy
Member
Reply #2 on:
25 Jun 2012 at 20:36 »
Hi Chris,
Many thanks for your input.
I had a browse through some pics of other machines and presume that this one is pretty near correct?
Do you happen to know what the size of the reg plate was?
Mine is 9.5" wide x 6.5" high.
Tony
Last Edit: 27 Jun 2012 at 21:40 by Dave
Logged
Print
Pages:
1
« previous
next »
General
